megane will not turn over!!
ive got a 1.6 16v megane coupe sport and when i try to start it it does nothing the key turns and it does not try to start can anobody help me out on this please?
- Currently Drives:: megane 1.6 16v
Re: megane will not turn over!!
i have the same sort of problem but it just clicks from some relays in the bonnet what does this mean?
- Anthony
- Rally Driver
Your battery is probably dead. Check it with a multimeter.
phil belfast wrote:i have the same sort of problem but it just clicks from some relays in the bonnet what does this mean?
The sound is the starter solenoid moving the gear into position. It also energises the motor, but as mentioned, there is not enough current to turn it over. The battery is discharged. Charge and or replace as required.
Users browsing this forum: No registered users and 55 guests
