Hello guys this is my first post here, i am from iceland i am having a bit problem with my Megane II 2.0 coupe
the problem is that i was changing my rear disc an i bought a disc that was without a bearing and without abs ring
i got the bearing out of the old discs but i can´t get the abs rings. i have looked all over the internet and all over my country but i can't find any abs ring to buy.
can someone help me pleas do someone of you know where i can buy only the abs ring or how i can get them off my old discs
and sorry for my bad English
A BIG problem
- Currently Drives:: Megane 2 CAUPE 2.0
- Ray
Re: A BIG problem
i don't think you can buy the ABS ring seperately. You either need a new disc with it attached, or remove it from your old one. It is possible but it's difficult, I've never done it but i do recall it being mentioned a lot in other posts. Use the search facility on the top right which should bring up some results.
Re: A BIG problem
im with Ray...i dont consider it difficult because its possible
just put it on the new disk with high temperature glue.
good luck
good luck
Users browsing this forum: Google [Bot] and 48 guests
