Please help. I am stuck with adding radar detector which gets its power supply from lighter and then wire goes all the way to 2 sensors which I have currently mounted left and right by registration plate. This is how it is supposed to be.
I have put sensors there, make the wire goes between reg plate and cooler and I get with wire to the engine compartment.
Now the big issues is that I don't know where to find a damn hole or any space to go with wire into passenger compartment. Megane II is 2006 make, 1,5 dci.
Wire (radar detector) from passenger compartment to engine
- Ray
Re: Wire (radar detector) from passenger compartment to engi
take glove box out. there's a grommet there
Thanks - will try tomorrow and let you know.
Glove box is down. I was trying, unsuccessfully, for an hour to find any hole, but no luck. Can you point for me where to search?
- Ray
i should have been more accurate, the grommit it on the LEFT hand side of the car as you sit in it.
So if you have a left hand drive car, it's somewhere above your pedals.
Right hand drive cars - it's behind the glove box.
Users browsing this forum: Bing [Bot], Google [Bot] and 58 guests
