BEEP BEEP BEEP.
william john
Currently Drives:: 2007 coupe cabriolet s 1.9 dci
BEEP BEEP BEEP.
Postby william john » Thu Aug 04, 2011 7:18 pm
Hi all. On my 2007 CC after starting thr engine i get a series of bleeps. The dealer says it is recognising the fact that the reverse sensors are switched on but it still happens when you switch them off and/or have the car in neutral. Does any one know if this annoying noise can be swithed off.Thanks in advance. William.
Boomstyliemikey
Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Re: BEEP BEEP BEEP.
Postby Boomstyliemikey » Fri Aug 05, 2011 10:15 am
Some else had this problem. Dont know if they ever sorted it out tho but this is a link to it
viewtopic.php?f=2&t=17424
tomalamix
Re: BEEP BEEP BEEP.
Postby tomalamix » Fri Aug 05, 2011 2:12 pm
when it beeps, does the reverse lights come on?
william john
Re: BEEP BEEP BEEP.
Postby william john » Sat Aug 06, 2011 2:21 pm
yes the reverse lights work.
tomalamix
Re: BEEP BEEP BEEP.
Postby tomalamix » Sat Aug 06, 2011 5:30 pm
ok, if it beeps (where it shouldnt) and the reverse lights are on (where it shouldn't because you dont have the reverse gear engaged), you have a reverse switch valve wrecked. its attached to the gear box and it can be easily accessed and swapped from the bottom of the engine bay
william john
Re: BEEP BEEP BEEP.
Postby william john » Mon Aug 08, 2011 9:37 am
Sorry. Confused me there. I meant yes the reverse lights work as they should when i select reverse and only then.
tomalamix
Re: BEEP BEEP BEEP.
Postby tomalamix » Mon Aug 08, 2011 1:29 pm
oh, thats a different matter then. your car have parking sensors?
william john
Re: BEEP BEEP BEEP.
Postby william john » Wed Aug 17, 2011 3:01 pm
Yes factory fitted.
tomalamix
Re: BEEP BEEP BEEP.
Postby tomalamix » Wed Aug 17, 2011 4:03 pm
check the sensors on the rear...i dont really know how to do it, maybe someone here can give a hint about that. If one of the sensors isnt ok you will ear that beep. further help appreciated.
cheers
