Air Bag Warning Light
Posted: Fri Jul 15, 2011 11:06 am
by AlanTR
The airbag and spanner warning lights are showing up on my 2008 Megane 1.5 dCi. The first time it happened, I switched the airbag off and on (switch by drivers door) and the warning lights went off. Now the lights are back on again and won't cancel. So, I guess it's a trip to the Renault dealer!
Anybody had a similar experience? Did you find a fix?
I guess this could get expensive at the Renault dealer but safety comes first. The warranty finished 3 months ago!!
Any advice appreciated...
Re: Air Bag Warning Light
Posted: Fri Jul 15, 2011 1:31 pm
by tomalamix
connectors under the seat. disconnect both and then reconnect again tightly. check again for the fault if it disappeared
Posted: Fri Jul 15, 2011 4:07 pm
by AlanTR
Thanks for the info.
I found multi-pin connectors under the left hand side front of the driver's seat and right hand side of the passenger seat. They have sliding locks you pull out to disconnect them. Is that the right ones or am I missing something? I disconnected and reconnected them a few times but no change with the warning lights.
Posted: Sun Jul 17, 2011 9:17 pm
by triumph2.5man
Hello Alan. The attached link might give more information about the mystical "connection under the seat"
viewtopic.php?f=2&t=16488#p98786Do you hear a rustling noise from around the steering wheel when you turn it? A bit like silver foil being screwed up.
Mike
Posted: Mon Jul 25, 2011 4:09 pm
by AlanTR
Thanks Mike & Tomalamix. I disconnected the main connector under floor carpet and took the passenger seat out and played around with the connectors, couldn't actually see anything wrong. Put it all back together and no airbag light when I started the car. For now all is good, but for how long? Ha ha!! Thanks again for the helpful pointers. Alan...
Posted: Fri Oct 28, 2016 8:18 am
by ricemalta
triumph2.5man wrote:Hello Alan. The attached link might give more information about the mystical "connection under the seat"
Mike
could you tell me the problem pls?
yes i'm hearing "rustling noise from around the steering wheel when you turn it" and the airbag light is on
