i have seen a megane 2 not starting , it is giving me a steering lock fault?, the steering is locked and cant get it unlocked
i read that this is likely to be a steering lock control module, is that correct?
how much are we talking for the module?, anything else possible to check?
cheers
megane 2 not starting steering locked fault
Re: megane 2 not starting steering locked fault
you can get ones of ebay for about 150 quid but they must be blank as they are coded to the car and must have had the code removed if fitting to another car.
when fitting a blanked one it won't need coding as the car codes it itself as long as the uch and keycard are in working order
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot] and 54 guests
