Caliper bracket bolts, HELP!!
The front caliper bracket bolts seem to be in some kind of rubber thing, can anyone tell me the tool and size of said tool that I will need to take the caliper off?? Many thanks
Re: Caliper bracket bolts, HELP!!
Anyone???
I basically just need to know the tools needed and how to remove the front caliper..
If its a standard megane its just a 10 or 13 spanner
cant remember but it just a normal size from the rear of the caliper
steve
steve
Do the rubber parts pull off? Do you know what I mean by the rubber parts..I don't know if I'm explaining myself very well..
In saying that... I might be looking at the wrong bit... I think I'm looking at the fitting to detach both halves of the caliper.. What do you think?
The bracket bolts are set on red Loctite. Just brush it away and add a drop of fresh Loctite. It is all in the manual in the sticky thread above the other threads. As no one reads it, the torques are: bracket bolts - 10.5 daNm+red Loctite, pillar bolts - 3.2 daNm, brake hose - 1.7 daNm, wheel bolts - 11daNm.
The tool... I used a socket. It was, probably, a star socket from a standard set.
I hope you are not confusing the caliper bracket bolts with pillar bolts. The pillar bolts are for changing the pads and the caliper bracket bolts are for removing the disc.
see pages 25 and 27 here:
https://ray-lee.co.uk/megane/dialogys/MR364MEGANE3.pdf
I think I may be getting them mixed up, I do have to change the disks and pads tho, is there a different tool needed for changing the pads??
It's the pillar bolts, they are confusing, they seem to be in a rubber casing, how can these be removed... Thank you
Users browsing this forum: Bing [Bot], Google [Bot] and 88 guests
