Is this a fault or normal function, if I take my foot off the throttle pedal completly and just let it go forward on it's own accord in mainly second gear, the car slows down as expected but will then pick up speed slightly and again slow down.
Is it in any way connected with the traction control function that is fitted to my car or something else.
Tickover when in neutral doesnt fluctuate.
2010 Scenic 111 1.9 dci 130 non-fap.
Throttle surge
Re: Throttle surge
It's going into the closed loop control at idle revs.
- Currently Drives:: Scenic 111 1.9dci 2010
Re: Throttle surge
Thanks for your reply Alexb not sure what this means? can you please explain as to if this is terminal or curable and if curable what is the remedy.
Users browsing this forum: No registered users and 104 guests
