My 2007 megane seems to have a delay wren changing gears. It went to 45 mph in 2!!
Also sometimes when driving along at normal speed the revs drop (this is not to do with it changing gear)
Some one has mentioned transmission fluid but I cannot find anything in the manual for it?
Has any one experienced this? Or point me in the right direction to find the transmission fluid?
Many thanks
C
Megane 2007 automatic gear change issue
- pw981
Re: Megane 2007 automatic gear change issue
when the revs drop, does it only happen once? and is it over a certain speed only? do you lose power/speed or anything?
2004 Megane II 1.9dCi
I can't say at what speed as it has happened several times but I would say between 25-35 but I know it's not to do with gear change. It drops so I push the pedal quite hard but it seems to drag? If that makes any sense??
My main concern is the slow change of gears in the lower gears? The revs are right up before it will change!
Users browsing this forum: No registered users and 86 guests
