mpg display
chewbacker
Currently Drives:: megane 19 dci
mpg display
Postby chewbacker » Fri Mar 25, 2011 9:34 pm
hi
is there a way of getting instant mpg displayed on my dash as most cars have this but meane 2's don't seem to
tomalamix
Re: mpg display
Postby tomalamix » Fri Mar 25, 2011 10:58 pm
yes, it have that. just roll over the total miles, mpg, etc etc menu and you will find one with the instant mpg.
cheers
fuzzy
Currently Drives:: getting a megane
Re: mpg display
Postby fuzzy » Sat Mar 26, 2011 7:35 am
yeh but you can reset it and use it for current travel
pw981
Re: mpg display
Postby pw981 » Sat Mar 26, 2011 11:37 am
UK versions (imperial MPG) don't show instantaneous consumption, where as European Meganes (Metric L/100KM) do, weirdly.
2004 Megane II 1.9dCi
chewbacker
Re: mpg display
Postby chewbacker » Sat Mar 26, 2011 10:47 pm
have been using average mpg but wanted to know if it can be modded as the car must work out instant mpg to get the average.
Ray
Re: mpg display
Postby Ray » Sun Mar 27, 2011 1:53 pm
pw981 wrote:UK versions (imperial MPG) don't show instantaneous consumption, where as European Meganes (Metric L/100KM) do, weirdly.
something to do with the calculations/conversion formula used. don't know why renault didn't put it in when other manufacturers do. maybe lack of space onn uch to store the code
tomalamix
Re: mpg display
Postby tomalamix » Sun Mar 27, 2011 2:07 pm
the UK cars doesnt have that feature? didnt know that..
well, if is important maybe is worth a try. with the CLIP software or an universal OBD computer you can choose an other type of units to be used, in this case the SI un its, maybe that way you will have that feature available.
cheers
Scenic
Currently Drives:: Scenic 111 1.9dci 2010
Re: mpg display
Postby Scenic » Mon Mar 28, 2011 10:50 am
What if you change the instrument panel readout from mph/miles to km/h/litres which you can do by pressing button 3 or 4 on the end of the wiper stalk and start button for about 10 seconds it will change to km/h would this then give the instant litres/per km? just an idea ;)
Re: mpg display
Postby joeishmather » Mon Mar 28, 2011 11:11 am
Worth a try... How do you change it back to miles tho?
If it doesn't work.
Scenic
Re: mpg display
Postby Scenic » Mon Mar 28, 2011 11:16 am
joeishmather wrote:Worth a try... How do you change it back to miles tho?
If it doesn't work.
Just do the same it will then revert to mph/mpg, its a system for when driving abroad.
pw981
Re: mpg display
Postby pw981 » Mon Mar 28, 2011 3:54 pm
I tried that on my Megane, didn't work.. may be programmable via CLIP according to the workshop manual though as there are a few parameters which can be set on the dials.
Scenic
Re: mpg display
Postby Scenic » Mon Mar 28, 2011 4:08 pm
Nice to know but worth a try, might try the clip next time round :-)
