feeble attempt to start, now wont turn over
slimpknz
Currently Drives:: Megane 06 1.5 Dci 106
Postby slimpknz » Tue Feb 08, 2011 9:13 pm
Hello only me again,
Megane 1.5dci, 2006 plate, 45000 on the clock, full service history
Tried to start 2006 dci after it sitting for 2 hrs after work , feeble splutter to turn car over then some white whispy smoke was seen to come from under bonnet / smell of burnt electrics. Now when I try to start it, all lights function outer and on dash, though no glow plug light illuminted, still refuses to turn over only a single clunck sound which i think is coming from the starter motor solenoid on each attempt. Now I recently posted on here regarding a leak from the fuel return pipe which I had sorted , was told at the time that starter motor could need replacing due to this sort of leak causing it to fail prematurly, but never had it done. Do you think that the starter motor is the most likely culprit due to the absence of glow plug light on dash , or would that indicate something else. Your opinions would be greatly appreciated. Thanks
Re: feeble attempt to start, now wont turn over
Postby davelowe » Tue Feb 08, 2011 10:41 pm
What condition is the battery in? Check that first.
slimpknz
Postby slimpknz » Wed Feb 09, 2011 6:08 pm
Ok had AA out, turns out starter motor was screwed, took to a local garage who replaced for £240. Didn't really show it was about to go either,not the cheapest but but not the worst, Arnold clark wanted £350. Thanks guys
slimpknz
Postby slimpknz » Wed Feb 09, 2011 7:00 pm
Tried 4 garages for recond one but couldnt source any, so had to be brand new from eurocarparts. Where were you yesterday Eddie when I needed you :cry
slimpknz
Re: faulty start motor see Eddie...he's got one in the garag
Postby slimpknz » Wed Feb 09, 2011 8:27 pm
Eddie you need to advertise more! :wink: Sorry just a little tickle about the title Eddie, I value yours and everybodys input mate.
slimpknz
Postby slimpknz » Wed Feb 09, 2011 9:02 pm
your a good sport mate , i had to get it goin cause I need it for work , but hey my big speak was about the fuel leak coming from the return pipe, as soon as you smell a wiff of diesel you have to act , or its your starter guys, and that can b expensive.........just look at me
slimpknz
Postby slimpknz » Wed Feb 09, 2011 10:19 pm
Hugz
