Weird window problem
Posted: Fri Feb 04, 2011 1:42 pm
We have a 54 plate Megane Scenic witha weird rear passenger window problem.
The window works both up and down, the problem is. If I use the switch on the drivers console the window will go down whether I press the up button or the down button!
The window will only go up if I use the switch on the rear passenger door but it will not go down!
The actual clip on the window rail snapped the other day which I have replaced so I have replaced that and whilst doing it made sure that all the connections to the motor etc were seated in. (the problem was there prior to the clip breaking)
Does anyone have any ideas?
