Standard Air Filter replacment
paulselby
Currently Drives:: Megane 1.6 16v
Postby paulselby » Thu Jan 27, 2011 12:27 pm
Hi
Does anyone know how to change the standard Air filter on a 05 plate Megane II
The filter housing looks extremely hard to remove, is this the case?
Thanks in advance
Paul
Ray
Re: Standard Air Filter replacment
Postby Ray » Thu Jan 27, 2011 7:18 pm
no. do a search. it might be in faq. else mods. its pretty easy. just 2 screws i think
steve-t
Postby steve-t » Fri Jan 28, 2011 7:03 pm
Undo the 2 cross head screws the top piece lifts straight out to reveal the filter
Try an ITG panel filter much better and lifetime usage
Steve
Boomstyliemikey
Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Postby Boomstyliemikey » Sat Jan 29, 2011 6:09 pm
Have you done it yet? I just done mine today. Its behind the battery. There are to screws on either side of it. Undo these with a really short screw drive and pull it up towards the bonnet. Its easy once u know what ur doing
limraaaah
Currently Drives:: Renault Megane II, 1.6 16v 3DR.
Postby limraaaah » Wed Mar 09, 2011 12:50 pm
Tried fitting a new air filter yesterday, no luck! Had the old one loose but there was no room to get it out. It was a struggle to say the least! :(
Once all the screws are out how do you go about getting the airbox out? Im replacing the whole thing.
Its a 05 Megane II
Postby Anthony » Wed Mar 09, 2011 4:01 pm
To remove the entire airbox assembly requires the battery, battery tray and ECU removing before it is accessible.
