pw981 wrote:did you get it sorted seanog5? ulrich100, incidentally my rear washer isn't working very well, sometimes it doesn't work at all and other times the 'pressure' of the water coming out is very low and it takes ages to start spraying. I don't think it's the pump, as I can hear it and I changed it a few years back. Any ideas?
I love how 9 out of 10 problems are now addressed to me.
Anyhow
What may have happened Is a build up 'algi' (green crap) in your pipes.
Thus causing a restriction in flow.
What I suggest is you buy a syringe, pour some 'Mr muscel' drain cleaner into it and force it through the pipe. (will take a few times)
This would involve taking the front bumper off for access to the feed and the rear nosel. (this could also be cleaned in warm water) .
Should clean the any restriction in the pipe.
