Good morning All,
Quick question regarding Hydraulic Clutch Bleeding and / or fluid replacement - is it required on the Megane or Scenic models?
Having changed the fluid in the brake lines a couple of times now. I am wondering if the clutch needs to have the fluid replaced or bled on the same interval? The Haynes doesn't mention this specifically, and I would like to know if by changing the brake fluid I am in fact carrying out enough preventative maintenance on the hydraulic clutch system?
Any tips or advice welcome as always.
Will.
2005 Scenic 1.9Dci 120 Exception
Re: Hydraulic Clutch Bleeding
Forum used to be good - Happy 2011 people...
Goodbye!
Goodbye!
No need to have a hissy fit. Bleed the brakes in the sequence shown in the Haynes manual. Use new fluid. By the time you have done the entire circuit, the little that is left in the clutch line will be diluted out in the new. Kein problem!
Some of us that post answers regularly might have had other things to do over the last few days.
Hi guys i have a megane 2 2003 1.4 and it has had a new clutch fitted and they have just i think fone a terrible job barely any clutch at all now im guessing it needs bleeding can anyone help me with this ive got a pint glass 2 litres of brake and clutch fluid and a clear pipe where do i start from here??thanks in advance
Rob
Rob
hi again
ok ive tried gravity bleeding as sudgested remove clip from slave pipe pull pipe out till click then wait with pipe in fluid ive done this and over 1 litre has passed through doesnt seem to be any air in system then i notice a small leak coming form where the black pipe enters the slave cylinder even with both clips in and pipe appears to pushed fully home it seems to be leaking fluid would this indicate that the pipe is at fault or the slave cylinder itself after bleeding it seems to have resistance in the pedal and can select gears with a bit of force but reverse grinds like hell im at my witts end here can anyone please shed some light on this for me??
regards
rob
regards
rob
- Rally Driver
i would not mess with it and it would be straight back to the people who did the job
have a look at the manuals here viewtopic.php?f=2&t=12790 to see if you can find help
Users browsing this forum: Google Adsense [Bot] and 85 guests
