water jets pump
l3ogroll
Currently Drives:: meggie 1.6 vvt
water jets pump
Postby l3ogroll » Mon Dec 20, 2010 1:10 pm
hi there boys and girls i have a prob with my water jets pump...
on the press of the stalk you don't evan hear the motor but everything else is working so i know its not the fuse... it was all fine befor the cold weather!
thinking my pump is gone or the water around the pump is frozen
its been snowing and we are in freezing temps just wondering if anyone else is having this prob in the cold weather?
thanks jay
Re: water jets pump
Postby davelowe » Mon Dec 20, 2010 3:29 pm
Hmm - the pump is likely to be fine provided you don't operate it too often with the plumbing frozen. Wait for a thaw and try again.
The temperature here this morning was -12C and this defeated my windscreen antifreeze. It also defeated the doors too. They were so frozen shut I had to crawl into the car via the boot.
I would be interested to hear what chemicals people are using if they are managing to keep their windscreen washers operable.
l3ogroll
Re: water jets pump
Postby l3ogroll » Mon Dec 20, 2010 4:30 pm
yeah it got to -4 an then kicked in again so it must just be the water at the pump blades freezing
seanog5
Currently Drives:: Megane GT DCi
Re: water jets pump
Postby seanog5 » Tue Dec 21, 2010 4:58 pm
mine has apparantly been frozen for a good 2 weeks and even the days when it went to +5/6 degrees it was still froze
i took it back to the dealer, only for them to tell me that it was just frozen, hmmmmm i looked a prick!
Re: water jets pump
Postby davelowe » Tue Dec 21, 2010 10:31 pm
Sweet! Lots of the 'mix yourself' stuff says 'protection to -46' or some such ballacks , but I reckon it would strip the paint if it were true.
Ray
Re: water jets pump
Postby Ray » Wed Dec 22, 2010 7:24 pm
i've got holts stuff. neat is down to -36.
stuff in canada goes to -50
philmegane1.6vvt
Currently Drives:: 2003 black renault megane 1.6 dynamique
Re: water jets pump
Postby philmegane1.6vvt » Wed Dec 22, 2010 8:05 pm
i`m using holts screenwash aswell. i use a strong mix and it has not froze once with temps -14. it works first time and helps deice screen aswell.
Re: water jets pump
Postby davelowe » Wed Dec 22, 2010 10:30 pm
philmegane1.6vvt wrote:i`m using holts screenwash aswell. i use a strong mix and it has not froze once with temps -14. it works first time and helps deice screen aswell.
Excellent! I shall get some. Has it faded the paint?
