How long can megane 2 be left unused and still function?
elchin88@hotmail.com
Currently Drives:: Megane 1.4 Extreme
Postby elchin88@hotmail.com » Fri Dec 10, 2010 9:19 pm
I have a 1.4 megane 2 extreme (07 reg) and it has done less than 30k miles. I am soon going away for 4 weeks. Anyone knows how long can the car be left unused and still function? Is 4 weeks too long for the car? Any help or previous experience shared appreciated. Thanks.
MéganeDynamique
Currently Drives:: Renault Mégane 2.0 VVT Dynamique Sport Hatch
Re: How long can megane 2 be left unused and still function?
Postby MéganeDynamique » Sat Dec 11, 2010 12:43 am
All depends on the condition of the battery. Mine was left while I was in Hong Kong for 4 weeks, came back and it started fine. But I was just in England for two and a half weeks, came back and it needed jump started...
ispellcorrectly
Currently Drives:: Megane 1.4 Oasis 5dr [Euro 4]
Postby ispellcorrectly » Sat Dec 11, 2010 1:50 am
Most enthusiasts keep their battery on charge while away, if you leave it too long, it can sulphate, which means the acid turns into a type of heavy white powder, if this happens the battery is useless... sometimes you might get it give you some life, but it's lifeline is very short there after.
Also, I believe jump starting the battery can damage the engine?
Postby joeishmather » Sat Dec 11, 2010 8:56 am
Hi, you'll be fine you just have to look at used cars in garages they can be on the forcourt for months and still be fine. But as said previously it's the battery what will let you down not the car, if I were you I'd buy a slow/trickle charger for the battey and leave it on while your away, will be fine and you won have any problems that way, there only about £20 well worth it imo.
Cheers, Joe
moon_monkie
Currently Drives:: Megane 1.5dci Dynamique 3dr
Postby moon_monkie » Sat Dec 11, 2010 10:15 am
Is it worth disconnecting the battery or is this likely to cause more problems?
Postby elchin88@hotmail.com » Sat Dec 11, 2010 9:17 pm
Thank you all... I will probably disconnect the battery and try to look for the radio code later...
Postby joeishmather » Sat Dec 11, 2010 9:35 pm
There are various radio code calculators on the net, that shouldn't be a problem...
Postby davelowe » Sat Dec 11, 2010 10:23 pm
Obviously, you can't lock the car with the battery disconnected. So, make sure you remove all items from the car and don't leave any of the key cards in the house.
Best bet in my opinion is to remove the battery and ask a friend/relative/neighbour to trickle charge it for a couple of hours each week. Either that, or remove the battery from the car and store it somewhere warm. It will therefore have a higher working current when you come to re-install it.
Postby joeishmather » Sat Dec 11, 2010 10:57 pm
Can the car be locked manualy by key when the battery is removed?
Victor Meldrew
Currently Drives:: 2003 1.6 dynamique
Postby Victor Meldrew » Sun Dec 12, 2010 3:50 pm
davelowe wrote:Obviously, you can't lock the car with the battery disconnected. So, make sure you remove all items from the car and don't leave any of the key cards in the house.
I'm with the solar trickle charger :idea:
Dirt cheap , simply stick solar panel in windscreen and plug in cigar lighter . Job Done , will charge on the dullest day ;)
John Wilkinson
Postby AlexB » Sun Dec 12, 2010 10:55 pm
Four weeks should be fine. If the battery is failing, then it may self discharge, of course. in this case just open the car with the key and replace the bugger (the next day delivery directly from Bosch). IMHO, there is no need in modifying the car when it comes to functions for which it was designed.
The battery can discharge over four weeks only is its self discharge current plus the standby current exceed 50mA. The solar panel will not provide the matching average current in the UK winter. Small panels give about 100mA in full sunlight, 10-20mA on a cloudy day and zero at night. The lighter socket is disconnected when in standby, so connecting the solar battery is slightly more complex than it seems.
