I know nothing about cars at all so bear with me.
Sometimes when i'm driving about, espically over speed bumps and sometimes braking a low speeds it feels like the engine is jumping forward or juddering.
More so when i'm over bumps i actually fell like the engine is going to drop out of the car.
Any ideas as to the cause, the cost of the fix etc.
Is this engine mounts?
Re: Is this engine mounts?
Don't laugh, this has already happened to someone a couple of years ago. Search for the nearest Bosch garage in their web site. They tend to be good.
Immobilizer wrote:...More so when i'm over bumps i actually fell like the engine is going to drop out of the car...
Yeah i have an FRM automotive Bosch garage up the road.
From those symtoms does that sound like it's the engine mounts as that is what i've been told? Pricewise?
I have no idea. Mine is a 1.9 diesel, which has additional engine support. Many people install the dog bone support link from 1.9dci into their 1.6vvt to make them feel more composed...
Ask the garage for the price. Consider an option of getting the part from ebay.
if you look at your top engine mount (left hand side at the top big rubber thing and part metal probably has a blue paint dot on it) there should be a gap that you can see clearly, this gap would be directly in between the middle of the mount about half a centimetre wide. if this gap is not there then the mount has failed. also a good way to see if your mounts are gone is to turn the car on ,open your drivers door and if its vibrating its most likely an engine mount ... first info confirms it top one anyways second just in general also renaults on mounts are around £150-170 for the top one fitted
hope this helps
hope this helps
- Currently Drives:: Renault megane dynamique convertible
not sure if too late, i got an engine mount replaced and fitted for £60, last week, they go, due to the amount of speed bumps our roads now have, shop around
Oscar-pepper - contemplating a change in car!!!!!!!
Users browsing this forum: No registered users and 97 guests
