Front suspension creak when low speeds.
Posted: Tue Nov 02, 2010 1:32 pm
I bought my megane back in 2008 - as i drove off i noticed a creak coming from the front suspension (i know this as when braking and accelerating at low speeds is when it could be heard)
i took the car to a local garage under warranty and the mechanic said it was nothing at all, just greased up a bearing under the bonnet and job was a gooden!
does this ring any bells to anyone? i have done 20,000 miles since i have had the bearing greased and the bearing has obviously dried up as it has started making the same noise again, the mechanic did say it will need regreasing again in the future. Does anyone know where this bearing is or how i can regrease it myself as the mechanic said it was easy enough to do.
Thanks!
Thanks!
