Tyre pressures
Posted: Thu Oct 28, 2010 4:17 pm
by joeishmather
What tyre pressure are ppl riding on? Preferably 1.5 dci owners bit interested to hear others, are ppl following what the car book says??
Re: Tyre pressures
Posted: Thu Oct 28, 2010 8:28 pm
by Ray
32 front
30 rear
Re: Tyre pressures
Posted: Fri Oct 29, 2010 12:18 pm
by aab
2.0 DCI 40 - 32 Slightly higher than recommended for the type of use
Re: Tyre pressures
Posted: Fri Oct 29, 2010 3:49 pm
by AlexB
See p.70 here:
https://ray-lee.co.uk/megane/dialogys/MR364MEGANE3.pdf
The unit converter is here (bar to psi):
https://www.digitaldutch.com/unitconverter/pressure.htm
Ray, your fronts are under-inflated!
Re: Tyre pressures
Posted: Fri Oct 29, 2010 10:24 pm
by davelowe
I'm on 32 front 30 rear unless motorway or towing. The 'book' (can't bring myself to call it a manual) says this. So does the door plate. Am I wrong? Has there been an 'update'?
Re: Tyre pressures
Posted: Sat Oct 30, 2010 1:44 pm
by Ray
well according to the post by AlexB, it should be 34/30. might give it a go next time i'm at the pump
Re: Tyre pressures
Posted: Sat Oct 30, 2010 10:09 pm
by AlexB
Dave,
Which "door plate"? I have two, one rectangular and one oval. None of them lists the tyre pressures.
I recently changed the tyres. The garage, obviously, inflated them incorrectly to 1.8 bar. They had the best intentions, but forgot that when the tyre is inflated, the air gets hot and then cools down, which leads to pressure reduction. The tyres got hot after a test drive on a motorway, especially the fronts. Then I adjusted the pressures and the temperatures went down. By the weight distribution of the car, it seems that 2.4-2.0 bar (35-29 psi) combination is about right. I am on Conti PremiumContact 2 205/60R15 91H tyres.
Dave, you are right, the figures I am talking about are for motorways, as noted in the factory manual.
davelowe wrote:I'm on 32 front 30 rear unless motorway or towing. The 'book' (can't bring myself to call it a manual) says this. So does the door plate. Am I wrong? Has there been an 'update'?
Re: Tyre pressures
Posted: Sat Oct 30, 2010 10:40 pm
by davelowe
AlexB wrote:Dave,
Hmm - interesting. I think there is a door sticker. If I remember correctly it's in a diagram form. I'll check tomorrow and photograph it (if it exists outside of my imagination).
