A couple of minor (i hope) problems. The clip that the fuel filler flap clicks into to hold it closed has broken. This is the 2 little arms im talking about but it is part of the filler cap, how easy is this part to replace? Anyone ever done it and knows the cost from renault please? Its a cabby by the way on an 54 plate.
The other one, the fan stopped working totally in the week. I checked the fuse which was ok but as i was on lates and the wife was using the car i havent looked into it. She now tells me its started working again, where should i be looking for a problem please?
cheers
Mick
Fuel filler and fan.
Re: Fuel filler and fan.
Hy there,
The fan is not always working. Why do you say that its failing?
- Currently Drives:: Megane Cabriolet 2004
Volvo C30
406 HDI
I mean the heater fan, the internal one not the rad or AC fan.
Mick.
Mick.
I would try all the settings, believe some people have had issues with heater resistor, I know the scenic had issues with them.
Alan
Alan
Megane CC 1.6vvt and 1.4 clio
Volvo C30
406 HDI
Done that, it didnt work on all 4 settings, lasted about 2 1/2 days then suddenly started working!!
Also the fuel filler, how do i get to the solenoid that locks it?
Mick
Mick
Eventually it will fail again if you dont find the reason of that failure...
You need that Clip to attach to the fuel filter right? I dont know if Renault sells that separately or only sells the clip with the all line attached...
Volvo C30
406 HDI
tomalamix wrote:Eventually it will fail again if you dont find the reason of that failure...
Um, i know, thats why i asked for some ideas!!
The clip, little 2 armed thing that the flap clicks into is the broken bit, appears to be part of the main filler so probably not available seperately, unless anyone knows any different??
Mick.
Users browsing this forum: No registered users and 68 guests
