Hi all, i changed my head light bulbs today on my estate as i found them quite poor (compared to our other cars xenon's). I bought some so called up rated bulbs and fitted them which was a bit of a pain. Now the lights are soooo bad its un true, i have used the manual adjuster but that doesnt seem to do much, there is a dead spot in front of the car. I have a phase two and have just pushed the bulbs in, i guess they could be in wrong but they are firm into the cluster.
Any advice, or are they just pap head lights?
Full beam is great, but i cant drive round like that all the time lol
any help would be great,
Rob
very poor head lights..... my mountain bike has better
Re: very poor head lights..... my mountain bike has better
You changed what bulb for what in what year's car in what model?
its a phase II megane DCI 130 estate. Has the projector type head light. I changed the standard bulbs (H7) for some Ring ultra xenon H7's.
- Gav
They're in wrong. It's quite a pain to seat them correctly - it took me a few hours of attempts before they finally clicked in correctly - and since I couldn't see what I actually did it's impossible to describe an easy way... If the wheel arch access is uncomfortable then it's probably best to remove the headlight units.
- direstraits
Don't forget to check the voltage on the bulb. 12V is what you need. A friend of mine bought 24V bulbs (for lorries) and complained about not seeing a thing.
As above there are more than likely no seated correctly.
Your best bet is to thkethe front bumper off which take 5 mins. 3 bolts underneath, 4 screews arches, 6 plastic retainers under bonnet.
You then have plenty of room to play with.
Users browsing this forum: Bing [Bot], Prepress2 and 52 guests
