Fitted a new Rear Caliper to our Clio III which is exactly the same as our Meganes.
All ok and bled ok too, but the handbrake on the new caliper is not holding as much as the other side.
Is there individual adjustment for each cable?
Handbrake adjustment
- Meggyman
- Currently Drives:: 56 Megane CC 2.0 Privilege in grey.
Full leather etc
56 Megane CC 2.0 Privilege in Grey.
Full leather etc
Full leather etc
Re: Handbrake adjustment
Odd. The 2002 - 2005 have a balancing bar in the handbrake internally - if yours is similar you can remove a small piece of trim and inspect the bar for left/right bias (obviously it should be equal). Because you have replaced the calliper, you may not have the same cable length where it attaches. I suggest you look at that end of things to rectify it.
Users browsing this forum: Google [Bot] and 83 guests
