Heating & AC won't go below 15 degrees!
My 03 megane has a problem with the heating/aircon, i can not put the temperature below 15 it will only go up. Any ideas or resolutions to this would be appreciated.
Re: Heating & AC won't go below 15 degrees!
You AC must not be turning on.
check fuse's for a start. Located under bonnet near battery.
- Ray
not quite sure what you mean.
if you have climate control, the lowest is 15 degrees. highest is in the high 20's... like 27 or something
- Currently Drives:: Renault Megane 1.9DCI
15 degrees is the lowest it will go... Well thats for the display but dont know what the actual temperature would be
Thanks for your responses. So there is nothing wrong with it then , I thought the aircon would have gone below 15 degrees but sounds like it doesnt.
mine goes down to 15 and up to 27 on auto climate control, you can get cooler I think if you turn the climate control off auto and just put the aircon on manually
megane cc 106dci 57reg quartz
The display for climate control will go no further down than 15 degrees...... but if you stick your air con on you should feel a drop in temperature. Is this the case or not? Because if not, your air con might need fixing.
Give it a test and let me know the results
Users browsing this forum: Google [Bot] and 64 guests
