On my Megane display it says
Press Clutch + Start OR Press Brake + Start
When I Press Clutch and start nothing happens apart from the cd player and clock powering up
When I Press the Brake and Start the car starts Fine.
So is there something wrong with the Clutch start or is do diffenerent megane have different starts sequences hence the OR
Starting the Megane (basic help)
- Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
Re: Starting the Megane (basic help)
Should be a switch on the clutch pedal, possiby a wire snsapped.
Alan
Alan
Megane CC 1.6vvt and 1.4 clio
- nickbell69
Yeah very common problem, have a look above the clutch pedal there will be a snapped wire. Just needs the ends stripping and re-connecting.
ok I have found the lead that has come off
I have took the plug off the accelerator pedal
on the plug there is a number 1 and 2 (very small
on the wires there is a black one and a black one with a white strip
Which wire do I connect to which side of the plug
thanks nik
thanks nik
Users browsing this forum: No registered users and 89 guests
