Card Reader
jr2010
Currently Drives:: 1.6v Dynamique 2004
Card Reader
Postby jr2010 » Tue May 25, 2010 7:58 pm
he card reader on my megane 04plate is playing up, i have changed the batterys in both key fob but still have the same problem, basically it fails to find the key when i place it the reader, after alot of in/out it eventually regonises the card and starts.
I have located a 04 plate which is being broken into parts and still has the card reader, my question is can you just swap it straight or is there a coding issue?
Thanks in advance
jr2010
Re: Card Reader
Postby Paddy » Tue May 25, 2010 8:49 pm
I dont think it is, but theres one sure way to find out!....
Re: Card Reader
Postby davelowe » Tue May 25, 2010 10:00 pm
Depends on whether the pairing is done between the key transducer and the reader integral electronics or the key and some other electronics via the reader.... There is probably a technical note about it (see the links section).
If you can get the salvaged bit for cheap, do an ulrich and try it! If not, best check!
Let us know how you get on. Good luck.
