limp mode check injection 1.4 petrol
Posted: Sun Apr 11, 2010 9:18 am
i have a 2003 megane II petrol 1.4 54K
it has recently started to go in limp mode when i drive it. it is this every other time i drive it and i have noticed that it only goes in limp mode exactly when the engine coolant temperature gauge is exactly quarter of the way up the scale. it does it when the coolant temperature is fully covering the quarter of the way up scale so that you canot see the mark. also when it comes up to this level of temperature if i only lightly press the accelarotor pedal it does not go in to limp mode.
the only fault code that i get with this is P0638: Throttle Actuator Control Range/Performance (Bank 1)
i have cleaned the throttle body
checked the coils
checked the plugs.
i am now thinking maybees a new throttle body or accelarator pedal or could it be something to do with a temperature sensor coolant or air.
i have had an elm 327 on it and the freeze frame data for this code is as follows:
P0638 is the dtc that caused this freeze frame data to be stored
Fuel system 1 status: closed loop control using oxygen sensor-normal
Calculated load: 72.5%
Coolant temperature: 75 deg C 167.0 deg F
Short term fuel trim bank 1: 3.13% lean (-)
Long term fuel trim bank 1: 10.94% rich (+)
Intake manifold pressure: 88kpaA 12.8 PsiA
Engine speed: 2189.oo rpm
Vehicle speed 68 kmh 42mph
so as far as i know i think the fault is related to coolant temperature and load of the car at this temperature.
hope someone can help
checked the coils
checked the plugs.
