Is it possible to adjust the camber on my Megane?
I have a lowered 120 Dci and it pulls to the left. The tracking has been seen to and I am aware of the roads having a slight camber.
But this is really noticeable, any ideas would be appreciated.
Would these work? H&R Triple C' camber adjustment bolts.
https://www.allsprings.com/camber.php
Thanks.
Camber adjustment?
- Currently Drives:: Renult Megane 1.9 Dci Tuned.
Camber adjustment?
Megane 1.9 Dci 120, 52reg. Tuneit Box fitted.
- Currently Drives:: renault megane 1.4 authentique
just bought 1.9dci privelage
Re: Camber adjustment?
sounds to me like the bolt is fitted where the bottom ball joint is attached to the strut, holding the ball joint at such an angle to camber the wheel more. but i would say that holding the ball joint at this angle is going to put unneccassary strain on the joint. i imagine the people who have these fitted are changing ball joints very regulary. and be warned over worn ball joints can come out of there housing, causint the front suspension to collapse and at high speeds inevutably you are going to crash
The steering column can be adjusted to eliminate pulling to one side. Read the manual.
Thank you all for your suggestions, much appreciated. J
Users browsing this forum: No registered users and 51 guests
