MANUALS, Technical Notes and Wiring Diagrams
Posted: Wed Mar 03, 2010 2:32 pm
by AlexB
Looking for a solution to a problem? Why not to start with the factory manuals and technical notes? The files listed below are pointed at in our Links section. You will need Adobe Acrobat Reader to open them.
https://www.dropbox.com/sh/355lr8566hrzhbg/mZ5Ub7cxRH
Please do not publish the above URL outside the members only area.
Please download the files just once and store them locally. Otherwise, the server will be overloaded and eventually will be closed. I have no affiliation with the server in question, and there exist other download locations. The same files are included into Dialogys CDs sold on ebay and also can be found on p2p networks.
Technical Notes:
0380A.pdf RECOMMENDED TOOL FOR REMOVING "FIR TREE" TYPE CLIPS
0396A.pdf sealing of joints
0420A.pdf SOUNDPROOFING PADS FITTED TO THE BODYWORK LINING
0435A.pdf PRECAUTIONS TO BE OBSERVED WHEN USING TWO-POT BONDING MASTIC IN A BETAGUN APPLICATION GUN
0448A.pdf KIT OF REPLACEMENT PARTS FOR THE BETAGUN SPRAY GUN
0476A.pdf SEAT BELTS DIFFICULT TO USE
0487A.pdf Replacement of front seat belt
0532A.pdf Special tooling for fitting crimped nuts and studs
0560A.pdf General procedure for bonding windows and sunroof assembly
0580A.pdf REPAIRING THREADING ON BODYWORK COMPONENTS
0586A.pdf Special bodywork features of the MEGANE Sports Tourer
0589A.pdf CONVERSION OF UTILITY VEHICLES TO PASSENGER VEHICLES
0625A.pdf Finishing product for use after work carried out on panelwork
0701A.pdf Registration plate mounting rivets
0826A.pdf CREAKING NOISE FROM THE REAR RIGHT OR LEFT-HAND SIDE
0850C.pdf FRONT ELECTRIC WINDOWS
0851A.pdf FRONT RIGHT-HAND AND/OR LEFT-HAND DOOR DIFFICULT TO OPEN OR CLOSE
2298A.pdf repair of plastic fuel pipes
2873A.pdf CONDENSATION, PENETRATION OF WATER INTO HEADLIGHT
2948A.pdf ANTI-POLLUTION TEST - DIESEL ENGINES
3090A.pdf METHOD OF FITTING THE DIESEL FUEL SUPPLY PIPES
3117A.pdf DISCONTINUATION OF ZINC APPLICATION ON WHEEL HUBS
3175A.pdf Fault finding Cooling circuit
3254A.pdf TRANSCODIFICATION OF TECHNICAL NOTES ISSUED SINCE THE BEGINNING OF 1994
3416A.pdf FAULT FINDING ABS - traction control 4x4
3419A.pdf DIESEL INJECTION TURBOCHARGER FAULT FINDING ASSISTANCE
3425A.pdf ELECTRIC SUNROOF
3451A.pdf Clutch: Fault finding aid
3481A.pdf Special features of Master vehicles fitted with 16 inch wheels
3515A.pdf APPROVED TYRES FOR 2001 MODELS
3585A.pdf COMPUTER PROGRAMMING AND REPROGRAMMING PROCEDURE
3598A.pdf Preparation of new vehicle before handover
3624A.pdf BLEEDING THE CONCENTRIC STOP CLUTCH HYDRAULIC CONTROL
3632A.pdf STARTER MOTOR FAUL FINDING
3633A.pdf WHEEL BEARING FAULT FINDING PROCEDURE
3664A.pdf 2002 MODEL APPROVED TYRES
3682A.pdf Inspection of batteries before delivery of new vehicles
3690A.pdf Special notes on Mégane Estate
3694A.pdf MEASURING VEHICLE DRIFT WHILE DRIVING
3700A.pdf FAULT FINDING LOGS
3701A.pdf FAULT FINDING - AUDIO EQUIPMENT
3707A.pdf AIRBAGS AND PRETENSIONERS
3761A.pdf Using the VIDEO ENDOSCOPE
3786A.pdf engine belt tensions
3799A.pdf CLEANING THE THROTTLE VALVES
3863A.pdf Electrical recommendations
3864A.pdf Using the Wiring Diagrams
3867A.pdf Shock absorber noise fault finding
3872A.pdf TURBOCHARGER
3876A.pdf FAULT FINDING GENERIC OBD DIESEL
3887A.pdf Remplacement des goujons de poulie arbre à cames K9 - K4
3916A.pdf EGR solenoid valve cleaning procedure
3924A.pdf Durability of safety pyrotechnic systems
3925A.pdf Cleaning guidelines for removal - refitting of diesel injectors
3955A.pdf Modification of axle assembly values and settings
3969A.pdf Repairing the plastic fuel pipes
3981A.pdf Modification to high pressure pipe tightening torque on K9K engines
3982A.pdf Wheel balancing
4382A.pdf OIL SEEPAGE BETWEEN THE AIR INLET DUCT AND THE TURBOCHARGER
4383A.pdf SUMMARY OF ELECTRIC POWER ASSISTED STEERING FAULTS
4400A.pdf BRAKE SERVO
4519A.pdf MECHANICAL DAMAGE TO THE TURBOCHARGER
4540A.pdf COOLANT LEAK FROM ENGINE RADIATOR
4559A.pdf GEARS JAMMING WHEN ENGAGING 2ND OR 3RD GEAR
4572A.pdf STEERING RATTLING ON FULL LOCK
4582A.pdf NOISE IN ENGINE COMPARTMENT AND/OR BATTERY CHARGE WARNING LIGHT ON
4901A.pdf SUMMARY OF MAJOR FAULTS CONCERNING CARMINA INFORMED T NAVIGATION HIGH END
5007A.pdf Fuel tank gauge assembly
5008A.pdf Alternator pulley: replacement
5011A.pdf Reprime high-pressure Delphi pumps on K9K engines
5024A.pdf Cleaning the direct injection circuit before an operation
5031A.pdf New negative battery terminal
5037A.pdf CODE SUPPLY PROCEDURE
6001A.pdf Air conditioning
6002A.pdf Checking and recharging batteries
6006A.pdf Engine workshop repair manual K9K
6008A.pdf SUMMARY OF ENGINE IMMOBILISER SYSTEMS
6012A.pdf Gearbox and final drive oils
6013A.pdf Engine oils
6014A.pdf CHECKING THE CHARGING CIRCUIT
6015A.pdf ELECTRICAL WIRING REPAIR (inc. the under-seat airbag connector)
6018A.pdf Maintenance
6025A.pdf Cleaning direct injection diesel engine fuel circuits
6029A.pdf manual gearboxes
6506A.pdf DEPHASER Problems
9300A.pdf TECHNICAL NOTES : CHARACTERISTICS
Workshop manuals:
Disassembly, fitting, service jobs
MR364MEGANE0.pdf Vehicle general information
MR364MEGANE1.pdf Engine and peripherals
MR364MEGANE2.pdf Transmission
MR364MEGANE3.pdf Chassis
MR364MEGANE6.pdf Air conditioning
MR364MEGANE8.pdf Electrical equipment
MR365MEGANE0.pdf Vehicle general information
MR365MEGANE4.pdf Panelwork
MR365MEGANE5.pdf Mechanisms and accessories
MR365MEGANE6.pdf Sealing and soundproofing
MR365MEGANE7.pdf Trim and upholstery
Fault finding
MR366MEGANE0.pdf FAULT FINDING INTRODUCTION FAULT FINDING INNOVATIONS
MR366MEGANE1.pdf Engine and peripherals
MR366MEGANE2.pdf Transmission
MR366MEGANE3.pdf Chassis
MR366MEGANE6.pdf Climate control
MR366MEGANE8.pdf Electrical equipment
MRINJDIESEL.pdf DIESEL
(*) the original location of the files is here. Please use the mirror, as listed above, unless it goes down...
https://www.uas-bg.com/meganii/eng
To download all files in one go under Linux just type in the terminal
wget -r target_url
The users of proprietory operating systems please consult the respective documentation or seek customer support.
Re: Index of Manuals and Technical Notes
Posted: Sat Mar 17, 2012 1:00 am
by AlexB
For the wiring diagrams search the web using the following search patterns:
Megane II X84 NT8206A -- (3/5 door hatch)
Megane II X84 NT8220A -- models 02/09/2002 (3/5 door hatch)
Megane II X84 NT8222A -- (non-hatch models)
Megane II X84 NT8227A -- models 01/01/2003 (3/5 door hatch)
Megane II X84 NT8228A -- models 17/11/2003 (non-hatch models)
Megane II X84 NT8266A -- models 20/06/2004 (3/5 door hatch)
See, e.g., this
https://krazh667.free.fr/rta/renaultelec/
Download the whole folder, then open index.xml inside with the browser (tried with Firefox). The above link is in French, but one can find similar in different languages.
If one wants to pay for a black copy of the same files, then search ebay for "RENAULT WIRING DIAGRAMS"
Re: Index of Manuals, Technical Notes and Wiring Diagrams
Posted: Tue May 15, 2012 9:36 am
by AlexB
The original post is updated with 2007-2009 manuals for Megane 1-2-3, airbags and Clio. Enjoy!
Re: MANUALS, Technical Notes and Wiring Diagrams
Posted: Thu Mar 13, 2014 2:07 pm
by freelanderuk
Manuals link
please feel free to access the manuals at this link
https://onedrive.live.com/redir?resid=4 ... 7F0B%21575:
Ray was kind enough to relocate the files we all need to his private space after the earlier used server became unavailable. Thanks Ray!
Everyone reading this thread, please feel free to download these files while they are still available!
