Clutch advice... (but not the car start issue!)
Posted: Wed Feb 03, 2010 11:03 pm
I think its fair to say I've not had a great start with my Megane II. I bought it two weeks ago, it broke down on the way home after only 100 miles when it wouldn't let me select a gear. The AA topped up the brake/clutch fluid and pumped the clutch pedal to bleed it which was enough to get me home. But the next day it wouldn't allow me to select a gear again and a top up of fluid refused to solve the issue. Of course the private seller claimed to never have had this issue so I've been left to sort it.
Since then my local independent garage advised me to replace the clutch plate, calm unit (slave cylinder) and flywheel. £700 later the car still has the same problem after less than a days local driving.
So what did I buy? Well apart from a problem car it seems, I bought a 2004 1.5 Dci 100 Expression 5 door with 89K on the clock.
The problem is, after the garage have bled the clutch system (which I'm told is really difficult), the clutch feels fine to start with but then quite quickly feels as if there is nothing there when you first push the pedal and only a tiny bit of clutch resistance at the end. Also when you release the pedal it doesn't follow right behind your foot, it has a slight delay before it returns to its normal position. The garage feel either air is getting into the system or the fluid is leaking out somewhere, but they can't see any leaks.
The garage feel the only step left is the master cylinder by the pedal itself. This is around another £70 I'm told plus labour.
Having searched the web including your forum, I can't find others complaining of the same issue? Has anyone had this issue before?
Also, does anyone know how long it typically takes to fit a master cylinder to a Megane II ?
From someone that just wants a reliable car...
