Running lumpy
laville1989
Currently Drives:: 54 plate Renault Megane Dynamique 1.9 dCi (120) Black, 3 Door
Running lumpy
Postby laville1989 » Fri Jan 22, 2010 10:07 pm
hi guys, got a 54 plate megane 1.9 dCi. When the engine has warmed up she starts to idle quite lumpy. When you are driving it, it is fine, it only lumpy when idleing. Any ideas?
black, 3 door, 54 plate megane 1.9 dCi 120 dynamique, GET RID OF IT!!!! IT HAS R@PED MY BANK ACCOUNT!!! NOTHING BUT F**KING TROUBLE!!!
jononfire
Currently Drives:: Megane 1.5 dci 80 dynamique
Re: Running lumpy
Postby jononfire » Fri Jan 22, 2010 11:17 pm
sensors need calibrating? might be running rich or something. it might be nothing. i know my 1.5 dci feels juddery on start up but once driven its fine. maybe drive it hard every now and again to flush the pipes out.
hope this helps,
regards
jonathan
Sold - Megane 1.5 dci 80, Black, Phase 2 Taillights, Colour coding, Spoiler, Reversing Sensors, Chrome Door Handles, Xenons, Interior Chrome Detail.
Currently - 03 Golf Comfortline. big plans
IainMW
Re: Running lumpy
Postby IainMW » Sat Jan 23, 2010 7:46 am
Do you mean the engine sounds like it's running on 3 cylinder or do you just get a lot of vibration through the car at idle?
This could be a number of things but more info might help the diagnosis. Mileage, service history, any other problems or warning light etc...
It only does it when it's hot? If you raise the revs very slightly (100-200rpm) does is go away?
joewin1975
Re: Running lumpy
Postby joewin1975 » Sat Jan 23, 2010 4:06 pm
hi, i just bought a 1.5dci a couple of days ago an im having the same problem, it does only go lumpy once warmed up and disappears if you rev ever so slightly, also as you slow down if you take out of gear its fine right up until you come to a complete standstill, im takin back in a couple of days for them to look at so any advice would be good.......
laville1989
Re: Running lumpy
Postby laville1989 » Sun Jan 24, 2010 2:24 pm
there just alot of vibration, and yes when u rev it very slightly it goes away. No warning lights, nothing. Just feels like its idleing a bit 2 slow
Re: Running lumpy
Postby davelowe » Sun Jan 24, 2010 2:30 pm
Does it idle fine when it is started from cold?
laville1989
Re: Running lumpy
Postby laville1989 » Sun Jan 24, 2010 9:47 pm
yep its fine wen started from cold. It only wen its hot
Re: Running lumpy
Postby davelowe » Sun Jan 24, 2010 11:19 pm
Mine had a dipping rev at idle problem a while ago, but new oil etc sorted it (never actually stalled).
Have you got decent oil in yours and have you cleaned the crankcase breather tubing? It can get very blocked with waxy deposits.
The temperature related thing is something I'm looking into at the moment. I have weird symptoms when the engine is hot (lack of power). I'm thinking about cleaning the EGR valve and checking the inlet manifold for blockages. I have a hunch there is a lot of crap blocking it.
wollyd
Currently Drives:: 1.5 DCi 100 Expression Megane.
Re: Running lumpy
Postby wollyd » Thu Feb 11, 2010 7:29 pm
Hi all,
I have a 1.5 DCi 100 Megane, it has a similar problem. Starts and idles fine when cold but when warm it is very lumpy at idle and sometimes can be very difficult to start. Otherwise it runs as normal, no loss of power or stalling. Any help or advice much appreciated. Also the gearbox can snatch a bit when coming out of gears. I was going to change the gearbox oil and see if that will help. It's a 2004 model with full service history and 46,000mls.
Cheers.
