During all this snow and wet weather ive noticed my front tyres are quite worn but not yet at the point of needing to be changed. I was wondering can i simply take the back tyres and put them on the front?
Im a cheap skate and dont want to buy new ones before i sell it!
Cheap option for tyres!?
- Hog
- Currently Drives:: renault megane 1.6 vvt dynamique
1.6 vvt Meg
- IainMW
Re: Cheap option for tyres!?
Yep, There no problems with rotating the wheels, infact that will even out tyre ware.
only if you don't have the added extra option on the car that gives you "the tyre pressure monitor", as then the sensors are programmed to the wheel. i don't suppose many cars have this fitted ?
- DJC013
- Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Hog wrote:During all this snow and wet weather ive noticed my front tyres are quite worn but not yet at the point of needing to be changed. I was wondering can i simply take the back tyres and put them on the front?
Hello, it is best to have your `best` tyres on the Rear of a FWD car, regards Damian.
- direstraits
DJC013 wrote:Hog wrote:During all this snow and wet weather ive noticed my front tyres are quite worn but not yet at the point of needing to be changed. I was wondering can i simply take the back tyres and put them on the front?
I agree with you Damian, and to add: it is wise to rotate the wheels regularly (I do it myself), to make them wear evenly. By doing this, you'll always have all the 4 tyres evenly worn, until they reach their limit.
Remember to swap only same side front and rear wheels as most treads are designed only to rotate in one direction.
- DJC013
davelowe wrote:Remember to swap only same side front and rear wheels as most treads are designed only to rotate in one direction.
Hello, thanks for that, should have said that too ! Regards Damian.
Hoggy - have 1.6 vvt and swapped tyres around every Christmas - and get around 45 k miles from each set.
Users browsing this forum: No registered users and 89 guests
