The other night I slid into a curb in the snow on the left front. I was going about 10mph and blew my left tyre and marked my alloy.
I have had a new tyre fitted, and tracking done. However, my car is drifting left when the steering wheel is straight.
I have two different make tyres on the front of my car could this cause it? Or could a buckled wheel?
When tracking was done underneath was checked and looked ok.
thanks
Kifty
Car drifting left
- direstraits
Re: Car drifting left
Different type tyres can have different diameter. You are in a situation where one tyre is worn, and the other is new I suppose? This can make car turn.
- Stranger
- Currently Drives:: BMW X1
You should always try and run the same make, model and condition of tyre on opposite sides of the car and, all around if possible. Get a second opinion on everything underneath after which I'd strongly suggest that you get a matching pair.
Tyre pressure has an impact too so make sure that both siades are the same pressure
- DJC013
- Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Hello, as posted previously it is not a good idea to have different makes of tyre on a FWD vehicle. You could try putting the rears on the front and vice versa and see if the pulling is still there, hope this helps, regards Damian.
Users browsing this forum: No registered users and 79 guests
