Hi guys been a while since iv been on,wel my probs started friday when i tried the washers for my windows and they didnt come on and the wipers didnt move either,the wipers work in normal mode but theres no sound from pump wen washer stalk is pressed,then my dash display were it shows time,temp and radio only lights up if i turn on my lights or just switch on the radio and the radio stays on when u remove key and open door,now my aircon lights and rear window lights dont work on the dash,they light up wen car lights are on but dont turn on when u press em,all ideas welcome,any pics of fuses in engine as it doesnt show in the manual,its a 1.4 2006.
thanx
Washers,wipers,aircon,rear window demister non working
- pw981
Re: Washers,wipers,aircon,rear window demister non working
Open the glovebox, to the left is a panel and behind it is a fusebox.
Check the 15A fuse with the picture of a radio on it. This fuse is in the middle row, 2nd one down, just below the ABS fuse. It is highly likely to be this fuse.
2004 Megane II 1.9dCi
- Currently Drives:: megane 1.6 2002
THANKS I HAD THE SAME PROBLEM, TRIED THIS AND ITS EASILY SORTED. THANKS A LOT!!
- Currently Drives:: 2003 Renault Megane 1.9DCI Dynamique
I got the same problem and with changing the fuse and trying out the sreenwasher again, it still keeps blowing fuses.
See my post detailing my problem.
viewtopic.php?f=2&t=12521&p=78610#p78610
Users browsing this forum: Bing [Bot] and 70 guests
