i'm new to here as i have just purchased my first megane 1.6 VTT 5 door 2004 reg.
i have a couple of problems and would appreciate any advice. the drivers and the back dorr window wont work any ideas what that could be?
also the sterring makes a clunking noise like a slight bang type noise i'd appreicate any help.
thanks
please help
Re: please help
a common fault is a failing top suspension mount that causes a "twang" at low carpark turning speeds.
with the car started and stationary does the sound appear when you turn the steering end to end ?
check fuses in the glove box area first, but window failures are usually failed motors / regulators due to water getting inside the door...if it is both on one side might have been the slope of where previous owner previously parked let the water in on one side ?
Re: please help
Cuby, use the search facility on this site on windows - bottom line main dealer fix is £ 300
Re: please help
thanks to you both for your replies.
markren yeah it happens when wse are stood still and i turn the steering wheel, its like a clunk sort of noise. thanks
chev - again thanks. can i get a regulator / motor off ebay and then get someone to fix it rather than having to go to the dealer??? thanks
jackie
jackie
Re: please help
cubahols wrote:can i get a regulator / motor off ebay and then get someone to fix it
Yes! Get quotes and make sure you order the right parts.
Re: please help
thanks
Re: please help
markren2004 wrote:a common fault is a failing top suspension mount that causes a "twang" at low carpark turning speeds.
Mine does this. Is it an easy/expensive fix..I've not got round to getting it looked out because i've had that much trouble i don't think i could cope with another huge outlay on this car of mine.
Users browsing this forum: Bing [Bot] and 62 guests
