Anyone had this issue?
Toolster
Currently Drives:: MG ZR until Sunday then 1.9 DCI 54 plaqte Mehane
Postby Toolster » Thu Oct 15, 2009 5:24 pm
Hi Guys,
Anyone had the issue where the handbrake light on the dash lights along with the stop light and the beep when on full lock to the right?
Only had my Meg since last Mon and the garge had it back yesterday but could find no problem and I have just found out its when full lock to the right when maybe going a bit quick but I have also had it happen when braking sharply.
Gonna ring garage again tom but would be cool to have a few ideas
Re: Anyone had this issue?
Postby AlexB » Thu Oct 15, 2009 7:11 pm
Worn brakes (pads or discs). When replaced, the fluid level will increase. If there is still some life left in them, then just top up the brake fluid reservoir. Use fresh DOT4 fluid only.
Toolster
Postby Toolster » Thu Oct 15, 2009 7:40 pm
ah ok cheers, the brake are sharp as, but will check the fluid tom, cheers for that
Users browsing this forum: No registered users and 67 guests
