Had AA OUT A FEW TIMES FOR THIS AND THATS ALL I CAN DO
Good work Renault
ulrich100 wrote:Check the grounding of the corresponding wiring loom. I have seen this problem before, generally due to build of sh1t around the exposed earth. The point can be located... if you open the bonnet and look down into the engine bay just behind the battery... you will see the earth bolted to the shell (14AUG black cable) . Remove it and clean with iron wool. This should put an end to the static build up/problem.
Users browsing this forum: Bing [Bot] and 69 guests
