Has or does anyone have a problem with wind noise from the panaramic sun roof on a 05 megane.
At 70+ you can't hear yourself think in mine. I've been told that i need a new sunroof cassette at 1500quid.
any ideas??
Wind noise
Re: Wind noise
Mine is fine at that speed, there may be a problem with your seals... As far as I know the Mégane uses engine pressure to inflate the rubber seal on closing the sun roof to give a water tight seal.
If there is a problem causing the seal not to inflate this could lead to wind noise and/or a water leak...
I will stand corrected on the above but I’m pretty sure it’s correct.
Re: Wind noise
Herr Ulrich, have similar problem - just tend to open and close it and its seems to reseat OK. If thats the onlly problem I have I'd be happy.
- rjacko
Re: Wind noise
Mine's a bit noisy, it does tend to lift the faster you go. Only cure I found is to turn vents to re-circulate not draw air in, seems to drop the pressure inside the car and stop it lifting.
- Currently Drives:: Megane II 1.9 DCi
Re: Wind noise
Yep, the noise is horrendous and wind starts whistling into the cabin as soon as my speed reaches 70mph. I think I'll need to go back to my dealer as the problems with my car are just mounting.
55 Plate Dynamique Pearl Black 1.9 DCi, 130 bhp
Re: Wind noise
eddiemcgarrigle wrote:Yep, the noise is horrendous and wind starts whistling into the cabin as soon as my speed reaches 70mph. I think I'll need to go back to my dealer as the problems with my car are just mounting.
Any problems you have with a meggy are easly fixed youreslf... One of the better aspects of the car
- direstraits
Re: Wind noise
I also get some noise round the windows on the German highway at 190Km/h.
Re: Wind noise
SEEMS THERE ARE PLENTY OF US WITH THE FAULT BUT NOT MANY CURES. I'LL HAVE TO START PLAYING ABOUT WITH IT AND SEE WHERE WE GO!!
Users browsing this forum: Google [Bot] and 65 guests
