Park lights on left hand side not working
Morne
Currently Drives:: RENAULT MEGANE 2.0T SPORT
Postby Morne » Thu Sep 17, 2009 1:05 pm
Hi
I have had a problem with my park lights on the right hand side. My front park lights located in the head light, the small bulb as well as the back . I have check and renewed the back bulb but still nothing. I think it is a power problem.
What im trying to ask, is there a seperate fuse for right hand side lights or one fuse for all park lights because its not a bulb problem.
I dont know if im explaining it correctly, but please bare with me.
If it helps the car is a Renault Megane 2.0L sport
RENAULT MEGANE 2.0L 225 SPORT.......WHOOOOOOHHHOOO AWESOME FUN!!!
moggiemegane
Re: Park lights on left hand side not working
Postby moggiemegane » Thu Sep 17, 2009 2:31 pm
Yes there is, it should be fuse 7A (7.5 amp) which is found in the fuse box under the bonnet next to the battery
Morne
Postby Morne » Fri Sep 18, 2009 8:05 am
Thanks, i'll have a look then.
A13XDT
Currently Drives:: 54 Plate Megane Dci 86 Rush - Platinum Silver
Postby A13XDT » Mon Sep 21, 2009 10:54 am
Just out of curiosity, do all the Megane 2's have parking lights? May be a stupid question but i have never sussed out how to turn them on in my Dci!
Alex
Morne
Postby Morne » Tue Sep 22, 2009 9:15 am
hi, yes it does. I can only explain to you where mine is. On indicate control stick there is a control that you twist to activate you headlights. There is two stages, first twist for parks and second for headlights.
This is how it is activated on mine, hope it helps.
steve the postman
Currently Drives:: 1.5 DCI 86 EXTREME TUNING BOX
DAB DIGITAL RADIO/DVD PLAYER
HID HEADLIGHTS
PIAA HORNS
GT LEATHER STEERING WHEEL
Postby steve the postman » Tue Sep 22, 2009 12:59 pm
Ah side lights! then dipped lights pull it main beam.
Steve
A13XDT
Postby A13XDT » Tue Sep 22, 2009 1:40 pm
Yeh I would have called them side lights, to me parking lights are the ones that stay on when you turn the car off at night. Either left or right hand side only, depending on which way you were indicating to pull in (on most cars anyway).
Alex
steve the postman
HID HEADLIGHTS
PIAA HORNS
Postby steve the postman » Tue Sep 22, 2009 6:17 pm
Yep like on VW and Vauxhall 's
Fuse is in fusebox underneath the top one in engine bay battery out ecu moved ect
Steve
Morne
Postby Morne » Thu Sep 24, 2009 8:09 am
I think im confused, must i take the battery out to get to the fuse box for that fuse . And does mean i must calibrate the windows?
steve the postman
HID HEADLIGHTS
PIAA HORNS
Postby steve the postman » Thu Sep 24, 2009 1:58 pm
Yes battery out and yes reset the windows
Steve
loronge2k9
Currently Drives:: 2006 1.4 sport 16v renault megane
Postby loronge2k9 » Thu Sep 16, 2010 8:10 pm
hi i changed my sidelights on my 2006 megane dynamique 16v and i left them turned on while i change the passenger 1 and as i went to slot it in it hit some metal i think and blew the bulb but it also took out the rear passenger main light the front passenger sidelight obvs lol and the centre radio and heat toggle lights out any ideas peeps if it could just be a fuse :banghead or summat PLEASE HEEEEEEELP!!!!!!!! :banghead
Users browsing this forum: Bing [Bot] and 54 guests
