Sunroof will not open.
My panaramic sun roof will not open. When i turn the knob i can hear the relay clicking but sunroof will not move. I have tried "the holding the button fix" but alas no joy. I am going to dissconnect the battery next to see if that resets any thing but that is going to be a last resort as i do not have my radio code. Any help would be greatly apreciated. Thank you in advance.
Re: Sunroof will not open.
how long have you held the button for? the roof takes a bit longer. id hold it for a good 40sec or so
The seals may have seized up if it hasn't been used for a long time. That happened on mine over winter a year ago. Luckily it didn't cost a lot to fix at local independent garage. I believe they only charged £50. You can use some sort of lubrication on the seals every so often to prevent it from happening and I believe also prevents rattling issue some ppl may have from sunroof. You just have to search the forum to find info on that and what lubricant used.
While waiting for my wife, I started to play about with the button. Pressing and holding it in different positions (it’s become a bit of an obsession) it suddenly opened. For the rest of that day it worked beautifully. Got in the car the next day and its back to normal. Now I am back to pressing and holding and pressing and holding. Please does any know the correct sequence as it is now getting very frustrating?
The correct sequence for the Megane is...
Something goes wrong with it, you take it to garage, they fix it, you give them loads of money, you drive home, it breaks down, you have it recovered, it is taken to garage, they fix it, you give them loads of money, you drive home, something goes wrong with it, you take it to garage, they fix it, you give them loads of money, you drive home, it breaks down, you have it recovered, it is taken to garage, they fix it, you give them loads of money, you drive home, something goes wrong with it, ad nauseum, infinitium etc.
My sunroof doesn't have a push button, it is one you twist. one turn to put it up, and turn through all the other stop to bring it right back and open.
Seriously... if you have problems with it try searching the forum for the right lubricant to use for the seals. If that doesn't work them you will have to take it into a garage and get them to look at it.
John
John
john10001 wrote:The correct sequence for the Megane is...
John
if you have the turn dial you will have the button..........
priceyboy wrote:While waiting for my wife, I started to play about with the button. Pressing and holding it in different positions (it’s become a bit of an obsession) it suddenly opened. For the rest of that day it worked beautifully. Got in the car the next day and its back to normal. Now I am back to pressing and holding and pressing and holding. Please does any know the correct sequence as it is now getting very frustrating?
turn it to shut. hold press the button for a good 40 - 50 seconds. if its not a mechanical falt it should work fine after this if it works fine then dies again my gues would be you have a lose connection to the battery. when the roofs power supply is cut it resets its self and forgets were open and shut positions are.... when you press and hold the button your in effect teaching it were these points are.... if you have a lose connection it will lose power wile driving and forget again
