Postby Toodeep » Fri Jun 12, 2009 9:36 am
The Megane I was a conventional medium-sized FWD hatchback (5-door, 3-door 'coupe' or fabric -roofed convertible) available until 2002/2003.
The Megane II was the much braver design you see above with a radical 'bustle-back' design. It was also available in 3 or 5-door forms as well as a Sedan (4-doors with a conventional boot) and a 'Coupe Convertible' (CC) with a partially glazed retractable hard-top. There is also a "Sports Tourer" version; essentially an estate with a compromised load space. Production ended in 2008.
The Megane III is the latest iteration introduced for this model year. The 3 and 5-door are out with a convertible to come.
Expression, Dynamique, Privilege, etc. are equipment levels. There are also performance variants.
Each Megane also has an associated MPV called Scenic (or the slightly larger Grand Scenic) with up to 7 seats.
