Steering Noise
meccano04
Steering Noise
Postby meccano04 » Tue Jun 09, 2009 10:11 pm
Hi folks
Ive noticed a click that sounds like its coming from just behind the steering wheel, it happens when the wheel is returning to the centre position after a right turn, and happens when the wheel is at about 10'oclock. Does anyone have any idea what it is? Its been in the garage a couple of times and all they've found is other broke bits (List: Exhaust back box, Track Rod Ball Joint, Lower Ball Joint, Suspension Top Mount - this was meant to stop this click) Im starting to wonder if they are guessing and its hurting my pocket (and my confidence in my otherwise great motor)
wallacesxf
Re: Steering Noise
Postby wallacesxf » Tue Jun 09, 2009 11:02 pm
hi ive have the same problem with mine.that horrible click when turning the wheel,please let me know if you find out prob mate
meccano04
Re: Steering Noise
Postby meccano04 » Wed Jun 10, 2009 9:33 pm
ive googled a bit and read something about a nut and bolt that may need re-tightened and then an adhesive applied to it?
Does anyone know what bolt this would be?
The only thing i can think it is would be the thing that knocks off the indicator, as the noise seems to happen at the point when the indicators would knock off
Re: Steering Noise
Postby AlexB » Wed Jun 10, 2009 10:03 pm
This is when it clicks on full lock. Otherwise, it might be something else. The bolt is in the driver's foot well.
meccano04 wrote:ive googled a bit and read something about a nut and bolt that may need re-tightened and then an adhesive applied to it?
