Hi I was just wondering if anyone else is suffering this problem as I have never seen rust on a megane yet and would it be covered by the anti corrosion warranty, I was polishing my 53 plate 1.9 dci priv the other day and found that the paint has bubbled about 1/2 inch from the bottom of the rear passenger rear door and is about 14 inches long, as far as I 'm aware the has never been any repairs or water problems in side the door
moggiemegane
Rust on rear Passenger door
Re: Rust on rear Passenger door
Little do you know the doors and water are best of friends, well going by the amount the doors like to retain. Just take off any one of the cards and you shall see what i mean.
As for rust, its something i am yet to see, touch wood.
- Kevin22
- Currently Drives:: Renault Megane Sport Hatch
1.5dCi 106
Dynamique - Location: Northern Ireland
I think renault has a corrosion warranty of 12years, correct me if im wrong.....so you should be covered!
Paint warranty i believe is a round 3 or 5 years.....i assume this is for paint which is flaking or door handles which have cracked! Check it out with ur local garage!
In my understanding the warranty is valid only if in every service they put the appropriate statement into your service book. Very few use the dealer for servicing after the first two years, the dealers usually conveniently "forget" to write the right words, so you are probably looking at buying some paint... You are right, Meganes usually don't rust.
moggiemegane wrote:Hi I was just wondering if anyone else is suffering this problem as I have never seen rust on a megane yet and would it be covered by the anti corrosion warranty, I was polishing my 53 plate 1.9 dci priv the other day and found that the paint has bubbled about 1/2 inch from the bottom of the rear passenger rear door and is about 14 inches long, as far as I 'm aware the has never been any repairs or water problems in side the door
moggiemegane
Users browsing this forum: No registered users and 71 guests
