megane 1.6vvt whistle noise
deni.babe
Currently Drives:: megane 1.6vvt
Postby deni.babe » Sat May 16, 2009 1:33 pm
hi all when i start my megane 1.6vvt in the mornings and accellerate i get a whistling sound for about 30 seconds and then it goes, :? anyone any ideas.
Ray
Re: megane 1.6vvt whistle noise
Postby Ray » Sun May 17, 2009 1:27 pm
one of the belts? someone will offer more assistance to you soon...
rockerdunn
Currently Drives:: Renault Megane 1.6
Postby rockerdunn » Sun May 17, 2009 4:13 pm
I don't know if my problem is similar. However in the mornings and only sometimes - usually when its cold or wet. As soon as I drive and put the clutch down, it makes a like squeal sound but it stops after around a minute or so. Any ideas?
deni.babe
Postby deni.babe » Sun May 17, 2009 7:01 pm
mine doesn't sound like a squeel you get when one of your belts is slipping it sounds similar to a turbo whistle , strange only happens first thing in the morning then fine for the rest of the day.
Busy_Man
Currently Drives:: 1.8 Zafira Life Auto
Postby Busy_Man » Mon May 18, 2009 6:56 am
rockerdunn wrote:I don't know if my problem is similar. However in the mornings and only sometimes - usually when its cold or wet. As soon as I drive and put the clutch down, it makes a like squeal sound but it stops after around a minute or so. Any ideas?
I'll second this, mine started doing it after the dephaser pulley was changed so I assume that a belt has been put on a little too tight. It doesn't appear to be doing any harm at the moment so I'll leave it as is till I next service it.
04 Plate 1.6 Dynamique
Issues to Date:
Dephaser - replaced
Cam Sensor - replaced
Start up problems, goes to two cylinders unless reved to hell - annoying, but untraced cause.
Water Leak in Boot - removed, came back, removed, came back again. Given up
deni.babe
Postby deni.babe » Mon May 18, 2009 8:38 am
yes mate i had my dephaser pulley changed last week you could be right about the belt ,strange that it only does it in the morning when cold .
Busy_Man
Postby Busy_Man » Mon May 18, 2009 3:19 pm
I put it down to the belt slightly expanding when the engine heat gets to it.
Issues to Date:
Dephaser - replaced
