No window washers front or back, no a/c or HRW
Posted: Sun May 10, 2009 9:38 pm
by Radiantpaper
Hi can anyone please help we have a renault megane Maxim 1.5 dci a 56 plate.Today we noticed that we have no window washers front or back, no a/c or HRW, alos the information for the time etc on comes on when the lights are on.
They stopped working after using the cig lighter to plug in an air bed inflator, I have chekedthe fuses and they dont look blown, not that I would know what one would look like.
Can anyone help or give any advice please,thanks if you can...
Re: No window washers front or back, no a/c or HRW
Posted: Sun May 10, 2009 9:56 pm
by sav0
this is what a blown fuse looks like
Posted: Sun May 10, 2009 10:28 pm
by Radiantpaper
freddymercurystwin wrote:Try replacing fuse G with another one of the same colour, your issue does point to fuses esp as you were doing something that is likely to cause it to blow.
Thanks for the pic, looking at my fuses none look like that all the wires go across. With out sounding thick what is fuse G?
Many thanks.
Posted: Sun May 10, 2009 10:35 pm
by Radiantpaper
freddymercurystwin wrote:Have you actually removed the fuse to look? It will be difficult to see without doing so. https://ray-lee.co.uk/MR364MEGANE8.pdf page 81C second fuse down according to the manual.
Yes I have then them all out, i think, and none look blown like the picture. Its a 15a fuse so I am going to replace all the 15a fuses. I understand there are more fuses under the bonnet, could there be a fault there?
Also looking at the diagram could it be B the Accessories relay?
Posted: Sun May 10, 2009 10:49 pm
by Radiantpaper
OK well I will take a look again tomorrow and let you know how I get on. Seems this has happened befor to otheres and the fuse is the trick, as nothing else is a problem I am hoping its the same.
Posted: Wed May 13, 2009 7:59 am
by Radiantpaper
All sorted now, was the 15a fuse 2nd one down (pic of a radio).
Thanks for advice.
Posted: Tue May 25, 2010 8:50 am
by dundeedek
I had my sat nav plugged in to cigarette lighter at the weekend and it was after that I noticed window washers not working. My radio wasn't switching off either when I opened the drivers door. Same solution- second fuse down. Thanks to all who added advice.
