Hi
I Had a problem with ignition coils But the nice R.A.C man fixed the problem with two new coils my question is should I have the other two coils replaced the car is a 54 Plate I had to pay for the parts on the road side but it still worked out cheaper than going to a Renault dealer
Ignition Coils
Re: Ignition Coils
If they ain't broke, don't fix them. It might be an idea to carry a spare pair with you just in case they do fail but remember that Renault recommend that you use their expensive grease on the coil to plug connection.
Re: Ignition Coils
Thanks for information on coils have brought two new coils whats all this about expensive grease that renault use!!!!!!!!!!!!!!!!!!
Re: Ignition Coils
quote below from an old thread...I think this is to mitigate the poor design/manufacturing of the early coils, and actually cheaper to put them on dry and have a couple of spare coils in the boot.
do you know which 2 the guy changed..they work in pair, outside 2 and inside 2, should always change at least a pair.
FYI, the grease is £45+ for a finger nail sized tube, although it is supposed to be enough for 100's coils.
AlexB wrote:The sticky stuff is the grease part number 82 00 168 855 applied according to the technical note 3789A. As I understand the coils must not be removed unless one is prepared to renew the grease coating.
The Green Note 4242A is about the coil types. It says that if a SAGEM coil fails and its production date is before "330-3", then all four coils must be replaced by DENSO. It is emphasized that the dates must be checked without removing the coils. If a single DENSO coil fails, then just one coil is replaced.
Users browsing this forum: Google [Bot] and 68 guests
