Can anyone confirm the procedure for reprogramming the throttle body once it has been removed, cleaned and replaced.
I read in the hints & tips section there is a reprogramming procedure if the battery has been disconnected for this job and there is a reference to document 80A.
Does anyone have this document or know the procedure?
Cheers,
Simon
Throttle body reprogramming
Re: Throttle body reprogramming
I did not have to reprogramme anything (2003 1.6). I assumed this would only be necessary if I was replacing a different throttle body from the one I took off. It works so I was right or very lucky.
- Currently Drives:: Megane II 1.6 VVT Dynamique 2003
Toodeep wrote:I did not have to reprogramme anything (2003 1.6). I assumed this would only be necessary if I was replacing a different throttle body from the one I took off. It works so I was right or very lucky.
The reprogramming is mentioned in the instructions for removing and cleaning the throttle body, thats why Im asking.
It may not need done but I would just like to confirm incase I have not done the job correctly.
- busternlouie
MONDO9 wrote:Toodeep wrote:I did not have to reprogramme anything (2003 1.6). I assumed this would only be necessary if I was replacing a different throttle body from the one I took off. It works so I was right or very lucky.
If you are just removing to clean the throttle body then you will not need to reprogram it. Its only when replacing the unit that reprogramming is needed.
Users browsing this forum: Bing [Bot] and 91 guests
