Change headlight bulb!
I used to curse Renault for this wretched design. But then I found out a lot of cars are in fact harder than this
I think the law should be changed and manufacturers are forced to make the changing of these bulbs easier. A bulb should be:
1. Replaceable in less than 10 mins.
2. Should not require any special tools.
3. Should be possible from under the bonnet with no crawling around under the car.
Renault Build A Better Car
I havn't tried my Megane yet, but it looks like a pig!
Having said that, the nearside on my Mk1.5 Focus was a swine as well and caused a lot of skinned wrists/knuckles.
I wish manufacturers would think this through - at least my Fiesta, because of the restricted access, allowed you to take the headlight out as a complete unit with only a screwdriver.
- nickbell69
Changing headlight bulb
Hi - it's me, Gordon, who started this thread. Yes, I was so cheesed off at the cost of £67.00 that after asking the dealer (Arnol Clark) twice to confirm they must remove front bumper I then contacted Renault UK and was phoned back by Customer Services there who confirmed that the charge was correct and that the bumper had to be removed to do the job.
Ho about that then!
Gordon
Ho about that then!
Gordon
- nickbell69
I'd be pointing Renault uk and Arnold Clark in the direction of this site. If so many of us diy mechanics can change them without removing the bumper(all be it in an hour!!) how come they have to? It also tells you how to change them in the handbook somewhere, as thats how i've discovered how to do it and i can assure you if it told me to remove the bumper i'd have had it in a garage. I'd take it further Gordon.
Changing headlamp bulb
I will keep you informed of further talks with Renault re. this and their reply.
Gordon
Gordon
- nickbell69
Good luck Ray!! Hope you have a nice warm garage to do it in or after about 30minutes your fingers will have no feeling and as we all know its a hard enough job in the "summer"!!! Let us know how you get on. We should start a table of peoples times for headlight bulb changing on a Megane. Olympic sport for 2012 i'm thinking.
changing headlamp bulb
Done both sides now on sisters megane passenger side took me nearly an hour after pulling things to bits wished I had found this site before that
,did it in about 10 minutes today (drivers side), easiest way is unclip windscreen wash bottle filler & push to the side, remove rubber boot from rear of lamp, twist lamp & pull out, fair bit of force needed to remove lamp from terminal housing, make sure notches on lamp fitment line up & twist back in, check operation of lamp before putting in headlamp unit
ensure located properly a tad fidgety, replace rubber boot - easiest way is locate it on bottom of rim & push on from there!
All in all not too hard to do but can see problems if not done b4!
Don't need to access via wheel arch or removal of bumper. Owners manual does say to contact Renault dealer (welll they would).
Dave
Dave
- Ray
Luckily I have slim hands but i still ended up with slice marks on my arm from the access port due to lack of room.
I say it took about 45 mins in total for both sides.
Turn wheels to far right (for both sides of car), remove access ports, reach in avoiding various metal beams in your way... turn plastic cover off and try not to drop it!
Remove power connector. Mine was firmly attached and needed force.
The hard part is now trying to figure out how to remove the hinged metal thing that holds the bulb in place. Took me 10 mins trying from the wheel arch but in the end i had better access from the bonnet if you can squeeze your hand between the battery and plastic covers on passenger side, drivers side isn't too bad.
Replace bulb (keyed part is on top), metal clip and power connector.
Next annoying part is putting on the plastic cover that protects the back of the lights... mine just kept on spinning as it wouldn't lock in place. Replace wheel arch port cover.
I'd say drivers side is easier but that might be because i did the passenger side first and had a better idea of what i was doing. drivers side took bout 10 mins.
Users browsing this forum: No registered users and 83 guests
