radio code
- Currently Drives:: Megane dci expression 80 1.5 2004
Re: radio code
Ive used various code generators, all give the same code (which matches a handbook found later) but it doesn't work. Is it possible someone re-coded the radio with a different code? Is there any way to rescue this radio instead of buying a new one?
Re: radio code
Sparklylisa wrote:Hi everyone, I can't seem to find the app on my iPhone??
Does anyone have a radio code for a Renault Megane serial number 8200483757T
Bought it off my cousin and he said he had to disconnect battery so has lost the code and never had a service book, any help would be greatly appreciated
Thanks in advance
Need more information from the lable on the radio ,you can not get a code from the numbers you have posted
- Currently Drives:: Sadly only a Grand Scenic but the kids will grow up one day!
Re: radio code
Hiya folks!
I'm in desperate need of the code for my radio before "the wheels on the bus" drives me mad!
My pre code is U527 I hope someone can help me!
Thanks in advance
Neil
Thanks in advance
Neil
Re: radio code
Proper job! Harmony restored, THANK YOU,
Re: radio code
freelanderuk wrote:try 5442
Thank you!
- Currently Drives:: 55reg scenic called Henry
Re: radio code
Same old problem, garage forgot to re-programme the code and I cannot find the original.
The bar code is 8200367490T
Is that enough info to generate a code??
Mark
Mark
Re: radio code
freelanderuk wrote:Wrong number
That's bizarre, those are def the right numbers for the bar code. In a box to the right, it says M406 Security
The other numbers are as follows:
RNR: RD4050011867
REN RDW231-10
FD: 0305340011867
Does any of that make a difference?
Re: radio code
freelanderuk wrote:try 1101the M406 is the number
Yep, that's it, many thanks.
Nice to get something fixed after spending the afternoon trying to mend some dodgy wiring on the hospital radio station that I help out on. We failed to fix it. Music service in the car now resumed, so all is not lost!!!
Thanks again
Mark
Re: radio code
Hi I'm looking for a stereo code can anyone help please
Re: radio codes
Hi All
Just bought Megane 225 trophy and blew clutch day I bought it
Now fixed but service book doesn't have radio code.
My serial number is 8200367486T
Can anyone help get code no stereo is killing me
Azza
Azza
- q292u
- Global moderator
Re: radio code
Tried a couple of these apps. They ask for a "pre-code" which is one letter and 3 digits.. Where would you find that?
- q292u
- Global moderator
Re: radio codes
AzzaG wrote:Hi All
Azza
It's an RS225, why would you want to listen to music when you can listen to that engine?
