Megane II Intermittant Squealing noise at startup?
nejkov
Currently Drives:: Renault Mégane II 1.6i 16V VVT Privilège Luxe Hatchback 5dr Ottoman Blue '04
Re: Megane II Intermittant Squealing noise at startup?
Postby nejkov » Fri Jan 22, 2010 12:24 pm
Please post a summary about defect and repairment after you get your vehicle.
knowlc01
Currently Drives:: megane
Postby knowlc01 » Sun Jan 24, 2010 8:06 pm
i have the same problem squealing noise on startup and for about 5 mins into driving until car is warm! ive changed the alternator and tensioner for the belt but noise still happens its starting to bug me now! any ideas what else it could be as my garage is clueless thanks!!
leeanderin
Currently Drives:: Renault Megane Expression 1.6 VVT
Postby leeanderin » Mon Jan 25, 2010 9:11 am
9 days later car back from dealer,clutch+bearing replaced squealing appears to have been fixed...
Nige
Postby Nige » Mon Jan 25, 2010 1:24 pm
Had a very funny feeling that was that the problem was.....Mine is making the very same.
How much did Renault charge you for a new clutch???
leeanderin
Postby leeanderin » Tue Jan 26, 2010 8:00 pm
Nige wrote:Had a very funny feeling that was that the problem was.....Mine is making the very same.
Renault didnt charge for the clutch they did it all under the Autoprotect warranty + it was the fourth time that they supposed to have fixed the squealing noise,so nine days later after car went into dealer fitted new water pump+coolant change,auxillary belt tensioner,cam+aux belt,clutch kit+bearing,clutch slave cylinder and a wash and hoover all under the warranty.......... :-)
Bertus
Currently Drives:: megane 2 2003
Postby Bertus » Tue Jan 26, 2010 9:36 pm
Hi, I have had same problem for over a year now. Mine is more like a grating / grinding sound, but only for a few seconds. Also happens only when cold. Took it in and they did full service andsaid it was cam belt. this fixed the problem for two weeks. service light came on and toxic fuel indicator. took it back again and computer said it was crank shaft censor. had this replaced which sorted the service light, but not the starting noise from cold. lasted two months and had another crank shaft censor replaced as the first one was "faullty" - no luck! Now service light comes on but goes away after three days' ignore. starting noise is intermittent, but now need to rev engine at 3000 rpm to keep it from stalling when starting from cold. Usually takes 4 goes to pull away from cold now. No problem when warm. Anyone any ideas?
:banghead
For you I would seriously question whether its the clutch as their / the computer's ability to diagnose problems seem to have disappeared leaving it to the dark arts of forums!
markren2004
Postby markren2004 » Wed Jan 27, 2010 8:08 am
Bertus wrote:Hi, I have had same problem for over a year now. Mine is more like a grating / grinding sound, but only for a few seconds. Also happens only when cold. Took it in and they did full service andsaid it was cam belt. this fixed the problem for two weeks. service light came on and toxic fuel indicator. took it back again and computer said it was crank shaft censor. had this replaced which sorted the service light, but not the starting noise from cold. lasted two months and had another crank shaft censor replaced as the first one was "faullty" - no luck! Now service light comes on but goes away after three days' ignore. starting noise is intermittent, but now need to rev engine at 3000 rpm to keep it from stalling when starting from cold. Usually takes 4 goes to pull away from cold now. No problem when warm. Anyone any ideas?
:banghead
is it a 1.6 vvt ? sounds like your dephaser, see the common issues viewtopic.php?f=2&t=8855
leeanderin
Postby leeanderin » Wed Jan 27, 2010 9:17 am
Sounds like Dephaser pulley my 2005 1.6vvt is on its third pulley now and had the same symptoms as yours.
Toxic fume light could be failing coils.....
Nige
Postby Nige » Wed Jan 27, 2010 12:25 pm
leeanderin wrote:UPDATE: Had a call from evans halshaw and apparently its the clutch throw out bearing causing the squealing noise? i am not so sure cos wouldnt the noise change depending on whether the clutch is up or down? Car at dealer for over a week now :x
Na dude, noice would only appear when the clutch is disengaged (Down) there would be room for movement. When engaged the clutch would be against the flywheel and locked in tight with no movement. Throw out bearing sounds about right to me!
bwautos
Postby bwautos » Fri Feb 10, 2012 3:04 pm
sounds exactly like a car we have in at the moment and i fully agree that it could be the clutch plate.
If i start the car with only the brake there is no noise if i start with the clutch depressed the noise appears.
very greatful for the info
Users browsing this forum: No registered users and 83 guests
